8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible),
159
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,684 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,684 | Mice got into the portion above the windshield this winter. I got some portions cut out and the mess cleaned up. Need to purchase the replacement and install.
1) Which type to buy? I’d prefer to stay original cardboard, but open to considering ABS if there is some consensus that it’s easier or better for some reason. Sounds like a PITA either way.
2) Install tips? I’ve read the tech tip about the ABS style. Anyone have a little tutorial on the cardboard if I go that way?
3) Insulation/sound deadening - At a minimum, I will do the adhesive foil/butyl to take some of the steel drum effect out. But it seems like I’ve read a suggestion to also do some foam for additional heat and sound reduction. What type and where to purchase?
1951 3100
