7 members (Jay R, Oswald, 55shaker, Joe H, Jon G, Phak1, dt235sd),
86
3
Mod | | | Forums66 Topics128,268 Posts1,058,391 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 1,721 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,721 | how bad is the rest of the cab? If you end up having to buy multiple panels for floors, corners and vent areas and then do the eyebrows you are better off financially and emotionally with a better cab stripped down. Many in the middle of the country I suspect if you go on a search. That was an approach I took. The eyebrow / windshield area is a challenging fix unless you are real good at fixing. | | |
