| | | Forums66 Topics128,101 Posts1,056,178 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Looks like a low mount water pump 235. Either of the two on the water pump itself could be used for one hose to supply coolant to the heater. The return hose from the heater would connect at the thermostat housing. As far as which way to connect the hoses at the heater, I would use the uppermost connection and route that to the thermostat housing to assist with purging any air from the heater.
