| | | Forums66 Topics128,281 Posts1,058,461 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,277 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,277 | Here's another link to the '59 Truck Shop Manual Supplement showing differences between oiling to the head between 1958 and 1969 235's. The separate oil line under the pushrod cover has been eliminated and replaced by a passage in the block itself coming from the lifter oiling gallery that lines up with the center head bolt.
