10 members (Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 1 invisible),
58
2
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Threads are 7/16-20. The best way to get new studs is to take an old one out and take it down to the local parts store to match it up. Or the Filling Station has two options. FS-631 and FS-631A They give dimensions for each that you could compare to your original studs.
