2 members (Ponchogl, Hush),
67
3
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,478 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,478 | Mike does it seem this way in third gear (or the final gear of either transmission)? Reason I ask is no matter what transmission you have it is very likely to have a 1:1 final gear and unless you have notably larger or smaller tires/wheels on one truck than the other, you should not notice much difference. In any other gear, we'd need to know the transmission type (3 speed or 4 speed) so we could know what each individual gear ratio is.
