| | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | the main question is. Based on your writeup you are trying to use the brake filament as the turn and the brake? (assuming you have a two wire two filament bulb one for parking one for braking/turn)
If you do that 5 wire setup is not going to work well. its designed for a separate turn signal light bulb on the rear
if you search NOS Signal Stat 700 with 5 wires and wiring diagrams you will see some nice writeups. This person has a 53 they did that type of wiring on and has a good diagram. The tech tip also explains this in detail as well. | | | |
Entire Thread
Adding Turn Signals, Help!!
| 22truckie | 06/17/2026 1:29 PM |
Re: Adding Turn Signals, Help!!
| Rusty Rod | 06/17/2026 1:36 PM |
| Gdads51 | 06/17/2026 2:20 PM |
Re: ADDING TURN SIGNALS, HELP!!
| hcb3200 | 06/17/2026 2:32 PM |
| Bill Hanlon | 06/17/2026 2:36 PM |
| klhansen | 06/17/2026 4:35 PM |
| TexasA&M48Truck | 06/17/2026 7:06 PM |
| Otto Skorzeny | 06/17/2026 8:54 PM |
| Hanks custodian | 06/18/2026 12:13 AM |
| 78buckshot | 06/18/2026 10:34 AM |
| Phak1 | 06/18/2026 12:22 PM |
| 22truckie | 06/18/2026 2:14 PM |
| 22truckie | 06/18/2026 4:02 PM | |
