I've had pretty good luck with using the thin stainless steel strip that secures the rubber in a windshield wiper as a shim behind a rope seal to make up for wear, or a seal surface that's been ground undersize. Use a few drops of red LocTite to help secure the shim to the block and main bearing cap before installing the seal.
