Winter is Coming
Getting it off took a little precise measuring, and taking my time. My garage is up a slight incline. It weighs close to 2000 lbs., empty.
Those are some lighter slings in the arsenal. 8000+ lbs basket. 4000+lbs straight pull. 18 foot, aluminum ends. I didn't feel like unpacking the steel end slings. Crane rated at 6 tons, 3 at each hook. Wheel ratchet strap are rated at 1000 each, the over the handle ratchets, 4000 lbs. I'd rather have too much rigging than not enough. No matter the lift. Especially when I seem to be surrounded by people that no longer care about load and load capacity.
