| | | Forums66 Topics128,080 Posts1,055,946 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | While making that sequence of tests (also known as a "series resistance test") do it in small bites, turning the switch off for a few minutes at a time in the process. Leaving the ignition switch on with the points closed for more than a minute or two at a time can result in burned points, and/or an overheated coil or ballast resistor.
