| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,807 | The injury accident I mentioned happened after the bellhousing, flywheel, and clutch was installed, and the engine was put back on the stand for final assembly. That changed the leverage just enough to make the assembly front-heavy. Jerry
