The misadjustment of the pedal to master cylinder pushrod will close up the relief hole in the bottom of the brake fluid reservoir. If that happens, fluid can't get back into the reservoir when the pedal is released and will eventually lock up the brakes. It shouldn't cause the master cylinder to leak.
Kevin
1951 Chevy 3100 work truck
Photos
