| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,723 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,723 | Assuming you've positively ruled out an exhaust leak, t sounds like it might be a stuck lifter or a valve tapping.
Perhaps a pushrod is stuck or bent. You'll need to take the valve cover off and observe the operation of the valves. Turn the engine by hand with the fan or hand crank and see if any aren't moving like they should.
Make sure you aren't low on oil in the crankicase.
1950 Chevrolet 3100 (Ol' Roy)
