| | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | What's more important, CFM or the size of the tank?
For instance, Harbor Freight has a 30 gallon unit that puts out 14.5 CFM @ 90 psi and 16 CFM @ 40 psi. Seems to me that the tank size is of little consequence if the pump can't produce enough air to replace what's being drawn from the tank.
Isn't it true that a larger tank just extends the amount of time the compressor is idle when you start draining the tank by using a tool. And if you're using a 9 CFM tool and you have a 7 CFM compressor the compressor will never catch up until you stop working.
But conversely, a 9 CFM will maintain operating pressure regardless of how long a 7 CFM tool is running.
Or am I missing something? | | |
