1 members (carbking),
77
3
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,186 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,186 | The joint between the brake pedal and the pivot arm should have serrations that help keep it in position. Also, the bolt needs to be TIGHT. Try some locktite as well as a new lock washer.
The clutch pedal scraping on the hole in the floorboard is a sign that the cab supports are collapsing. Something needs to be shored up or repaired.
