Winter is Coming
Interesting lash up for lifting the body. I'd be sweating bullets waiting for it to flip over. But it looks like you got it set on the frame.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
