| | | Forums66 Topics128,108 Posts1,056,567 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,105 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,105 | It's possible that the rear shaft bushing is hung up. Normally it can be pushed back to allow the oakie bushing to go all the way in. I just watched a video of someone trying to put an oakie bushing in a 35 Chevy car and he had a problem with a washer behind the seal that was up against a shoulder in the torque tube that was not letting the oakie bushing go all the way in. He had to remove the rear axle/torque tube and get the washer out which allowed the new oakie bushing to go in far enough. Maybe you can use a piece of pipe that will slip over the driveshaft and drive the bushing back into the tube. Did you drill out the pin holding the rear bushing?
The oakie bushings for 1950 earlier trucks that are held in place by dowels I believe are smaller diameter than the later ones that just depend on the press fit. Maybe it's possible that you got the wrong bushing and is too big for your torque tube.
