Hello,
I purchased a rearend that was supposed to be a 1949 with a 1955 differential but not convinced it is a 1949. I am installing it on a short bed 1946 frame with a 700R4. I am planning to use the old parking brake setup for a 1946 with the rod running from the tranny to the cross member. I have already built the parking brake bracket to the tranny. Does anyone know if the 1946 parking brake cables work with that model of brake system. I have 11 inch drums with non-self adjusting drum brakes.
