| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,948 | You need to separate the two pieces of the sensor bulb in the last photo. Then the square head fitting will thread directly into the head. The sensor bulb has a shoulder that bottoms out in the counterbore below the threads in the head. That adaptor appears to have a 1/2" NPT male thread to fit the later model heads. Jerry
