| | | Forums66 Topics128,142 Posts1,056,490 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2021 Posts: 27 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 27 | Thanks for your response. That’s a beauty of a truck you have there. I had success with the linkage this morning. I left the speedometer linkage unhooked and started with getting everything else adjusted till lever and rod length were correct. I did then turn reducer unit till it centered and worked well. Is there a stiffener arm or bracket to keep reducer unit from ‘wiggling around a bit even though I retightened clamp screw ? Thanks | | |
