9 members (Woodcmiami, dt235sd, MickeyP, Gdads51, HandyAndy, k2handyman, chevy51truck, Otto Skorzeny, 1 invisible),
63
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15927 08/25/2004 6:03 AM | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | Ritchie,
Radiator support gaskets are shims used to adjust the front clip fender assembly that attaches to the radiator support. No order is used. The slotted ones are installed or removed easily as needed to adjust the front clip.
Set the hood first, then raise the fenders to fit the hood using the shims under the rad. support. Also the fenders will move independently up and down at the attaching point on the radiator support as needed.
Carriage Bolts drop in from the top.
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
