Yes, I am going through the whole brake system, replacing every everything including the lines. The brake drums measured .060” over the maximum acceptable rebore diameter. So, they are shot. Leading me into replacing the studs.
Thank you for the link on steering ball. I looked at the video for the tie rod ends. Is there a replacement for the drag link balls as well?
