| | | Forums66 Topics128,185 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,172 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,172 | Putting the add-ons on the engine isn't that tough. And $5k for rebuilding a long block isn't that bad. I just had a 7.3L diesel rebuilt and it cost me ~$8k for the long block returned to me. Myself and a buddy bolted everything else on and reinstalled it. Yes, it was some work, but nothing super technical. We could probably talk you through installing the stuff on a long block. I'll bet the shops local to you could rebuild your 270(s).
When I lived in CA ages ago, engine swaps could be registered with DMV. And that should only matter if the registration was done with an engine serial number instead of vehicle serial number. But that was before smog checks. Your trucks are likely old enough not to require smog checks. Call DMV and ask about it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | |
Entire Thread
Engine Rebuilding, 270 GMC, Who Still Rebuilds?
| MikeStone1953 | 10/08/2025 8:36 PM |
Re: Engine Rebuilding, 270 GMC, Who Still Rebuilds?
| klhansen | 10/08/2025 10:06 PM |
| Hotrod Lincoln | 10/08/2025 11:15 PM |
| KDrown | 10/09/2025 12:18 AM |
| FAST55 | 10/09/2025 12:48 AM |
| TrknGMC | 10/09/2025 1:11 AM |
| MikeStone1953 | 10/09/2025 3:11 AM |
| Hotrod Lincoln | 10/09/2025 3:37 AM |
| MikeStone1953 | 10/09/2025 9:15 PM |
| klhansen | 10/09/2025 9:39 PM |
| Otto Skorzeny | 10/09/2025 9:40 PM |
| Truckrolet | 10/12/2025 8:06 AM |
| Hotrod Lincoln | 10/12/2025 8:44 PM |
| Truckrolet | 10/12/2025 10:24 PM |
| klhansen | 10/12/2025 11:11 PM |
| Hotrod Lincoln | 10/13/2025 12:46 AM |
| Truckrolet | 10/13/2025 3:06 AM |
| Hotrod Lincoln | 10/13/2025 3:40 AM |
| JW51 | 10/13/2025 2:24 PM |
| Hotrod Lincoln | 10/13/2025 3:22 PM |
| Hotrod Lincoln | 10/13/2025 4:42 PM |
| Truckrolet | 10/16/2025 4:51 AM |
| Nuts&Bolts | 10/17/2025 3:24 AM | |
