| | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | If you grew up in Atlanta, the electrical grid probably had sufficient capacity that you wouldn't see it.
In some of the older rural houses on REA, the picture would shrink from both top and bottom by as much as a couple of inches when the extra starting current from the compressor created a momentary low voltage. The dip would last maybe a second or two. Things electronic like stable voltage.
While the output from a generator might average the 14.5~14.7 volts Jerry mentioned at idle, the voltage isn't as stable as that from an alternator.
Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
