| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | The Filling Station sells the gray engine paint in rattle cans, but the stuff from either Jim Carter or the Filling Station in pint or quart cans can be brushed on with good success. I used Jim Carter's ALK-200 engine paint, originally spraying it, but touched up the block after it was hot tanked with a brush. Filling Station Engine Paint
