| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15873 05/16/2005 1:41 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Holley 390 cfm 4bbl on a Patrick's intake.I carefully checked the carb,disassembled the metering block,looked for junk in the idle restriction jets. The engine must be fully warmed up for the misfire which eliminates a lean condition at idle since it idles well when partially warmed up. I suspect ignition,the tach needle flickers ever so slightly with the misfire. | | |
