I’m assuming you’re referring to the cast iron plate and not the carbon bearing. If it’s similar to a 1/2 ton, the plate springs (0.814) are installed on the plate (0.800) prior to installing plate. They are left rotated in the disengaged position. After installing the plate, the springs are rotated on to the levers. Hope this helps.
