10 members (BarryP, mick53, Bill Hanlon, rfs56trk, Nick in Manitou, UtahYork, NorCal52Suburban, Hanks custodian, Donf, 1 invisible),
140
3
Mod | | | Forums66 Topics128,136 Posts1,056,745 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,910 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,910 | You have been running rich. There's no need to choke an engine after it starts.
You're going to have to check the basics. Make sure your timing is correct.
Set the octane selector on the dizzy to "0" and then make sure the BB on the flywheel is at the pointer.
The mixture screw on your carburetor should be adjusted out about 1 1/2 turns.
1950 Chevrolet 3100 (Ol' Roy)
