| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | It would be much more effective to use a shroud instead of moving the fan. A shroud should only cover half the fan blade, however- - - -put the back end of the shroud even with the support spider where the blades are attached. Jerry
