I’m using that aftermarket bearing race at the engine side of the column after shortening. I did ground the tube, but the high opens in the bearing was the issue. No solid continuity from the tube thru the bearing to the rod. I finally ran a strap from the isolator at the rack to the steering rod. Problem solved. I’ll put a couple of small stainless straps to hold it down, but may not need to.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
