I believe the factory manual specifies the clearance between the cam and retainer. As I recall, it's more than 0.001, more like 0.010. You have to account for the aluminum gear expanding at a different rate than the steel cam and retainer.
1951 3800 1-ton
"Earning its keep from the get-go"
In the DITY Gallery
1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
