3 members (2-Ton, Mike B, 1 invisible),
69
2
Mod | | | Forums66 Topics128,030 Posts1,055,419 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Mostly because most of the "one wire" vendors share a situation with Pinnochio- - - -one of these days they're going to have a long nose. In other words, they're lying. Some (not all)"one wire" alternators have different regulator internal wiring so those terminals on the perimeter of the alternator aren't needed. They usually have a rubber plug installed in the rectangular slot on the perimeter of the housing. If you've got one of them, just connect the heavy gauge charge lead and drive on. If the two blade terminals are exposed, wire the thing the way GM engineered it. Jerry
