After your done blasting spray it with some metal etch. I've used both Jascos' Metal Etch and Rustmort. Rustmort seems to be a little better, but the only place I've been able to find it is at an auto paint supplier. Jascos' Metal Etch works good and you can get it at Ace, OSH. It's a little cheaper than Rustmort too. Both are essentially phosphoric acid. Either will kill the flash no problem.
Larry
I don't own a vehicle that isn't old enough to drink.
