| | | Forums66 Topics128,056 Posts1,055,806 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | One word of caution if anyone plans on using a spin-on filter in a bypass application- - - -you MUST put a flow restrictor somewhere in the circuit or you'll drop the engine's oil pressure to virtually zero. Bad Juju! I use a Holley carburetor jet with approximately a 1/16" hole in it, threaded into one of the fittings that supply oil to the filter adapter. In general, full flow style filters don't do nearly as good a job of filtering the oil as a bypass element does- - - -the media has to be a much looser weave to allow a sufficient volume to flow through it. It's a "feel good" thing that makes people think their oil is getting cleaned up. A 1 micron hydraulic oil filter, or a Diesel fuel filter does a much better job of actually straining out the small stuff. Jerry
