| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | A little Dawn dishwashing soap (the blue stuff) will help and it won't hurt the rubber. Rub a layer on the inside of the rubber. I use 1/8" cord...poly type. You didn't mention whether you have the type that includes the stainless molding. That is another discussion (for which I posted some hints & notes the last time I did one). If that is the case please make certain you install the molding first and let us know. As I said, a slightly different bit of work there.
