| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | I have replaced the shaft and flapper with stainless steel parts running in brass bushings. I make the bushings from 1/8" NPT pipe nipples, threaded into the manifold and line-reamed so the shaft runs true. Lots of work, and fairly expensive, but that fix lasts about 3 days past forever. Jerry
