12 members (HandyAndy, 3B, Oswald, Gdads51, 1955 1 Series, Jon G, Southerntruck, Otto Skorzeny, Gray_Ghost, Peggy M, 2 invisible),
155
2
Mod | | | Forums66 Topics128,103 Posts1,056,183 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | As long as the ball on the lash adjuster is still round, the original setup does a good job- - - -just do a valve adjustment occasionally to maintain the proper clearance. If the ball on the adjuster wears and develops a high spot in the middle, replace the adjuster. That can cause the end of the pushrod to crack. Also check for wear on the rocker arm tip where it contacts the valve stem. Jerry
