8 members (52Carl, Lightholder's Dad, BarryP, Cletus1950, Otto Skorzeny, Dennys28, 1955 1 Series, 1 invisible),
383
2
Mod | | | Forums66 Topics128,164 Posts1,057,080 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Forget the air bags- - - -and the Panhard bar. Just install spring shackles a couple of inches longer. Flatter U bolt plates are a good idea. You can also fabricate a square tubing crossmember behind the axle to serve as an upper mounting point for shock absorbers. Lower shock mounts can be welded to the axle tubes just inboard of the springs, or clamp-on mounts for a Winters or Halibrand quick change rear axle tube for a dirt track car can be fitted to your housing. Jerry
