| | | Forums66 Topics128,282 Posts1,058,490 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 6,218 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,218 | Mike - Before you get too much further you should take a look at the fuel pump cam lobe to make sure it didn't get chewed up or damaged when that arm self-destructed. That and checking for any other random contact with other internals to be sure nothing else got banged up or a piece got lodged somewhere to later fall out or get stuck in the rotating assembly and cause further damage.
Have you tried to puzzle piece assemble all the bits and pieces together to be sure you found everything that was once one piece? It might give you better peace of mind when you start putting things back together.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
