I THINK that the accent color is the darker of these two (picture 1.) Although the second pic (don't remember where I got that from [on edit - it was from Tim Lederman's site) says that mid-'51 and later trucks didn't use the accent color (noted as Metal Gray, Duco No. 739 in pic no 2) and the entire grille was painted interior color, Sheen Gray Metallic, Duco No. 740. Interior color info is pretty hard to come by. I painted mine just interior color with no accent striping.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
