Hello and Thanks to Guitplayer, 78Buckshot and Crummy, Hoorah! Speedometer now working. Checked trans. speedo. gear by looking into trans. hole and turning rear wheel, Checked speedo. gear on side of trans., Checked speedo. cable by hand turning counter clockwise, lubed cable. All checked out fine (I thought). Still when reassembled did not work. Rechecked everything again. Closer inspectio, revealed the end of speedo. inner cable slightly worn near end (see photo). Replaced speedometer cable, re-assemble, test drove, works great! Chuck 52
