3 members (59Kid, 51sub, delky),
111
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,280 Posts1,058,591 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,282 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,282 | Stock wheel width would have been 4.5 inch wide. 7 inch wide wheels would be 1-1/2" closer to the steering components assuming the same offset as stock wheels (which are pretty close to zero offset, IIRC.)
You should measure the offset of those wheels (back rim to wheel mounting surface). Or you can just bolt them on and see.
