2 members (Phak1 , Tom McGrath ),
119
1
robot. Key: Admin ,
Global Mod ,
Mod
Topics128,274
Posts1,058,433
Members48,490
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Herder of Cats, Goats, and Sheep (moderator)
Check the headlight fuse for power in both ignition off and ignition on positions. Then pull the fuse and make sure that the headlight fuse is actually what is powering the headlight feed. Based on the wiring shown in the documentation, there shouldn't be a way for you to hook it up such that the ignition switch controls the headlights.
