Hi all,
Wasn't really happy with the 2nd video above, so I reshot it, adding voice and issues I'm seeing with how to replace the rod between the pedal pivot and rear wheel brake pivot.
One thing to note, after comments about the rod being a single piece, and the part I received today BEING a single piece. While my vehicle has 2 rods, and they are bent in such a way the rod pivoting is needed... there seems to be no reason why it needed to be done that way, from the pedal pivot back a straight rod should work. Now all I need is ideas on how on earth to remove the existing rod in order to replace it (watch the video link and you'll see what I mean.
BTW, if folks are uncomfortable clicking a Dropbox link... just let me know (I understand :-)... and I'll see if I can capture it good enough in pictures to explain my issue. For now, here's the better Video #2.
Pedal End Issue
