Thanks Dan.
Indeed the picture of the part from Classic looks to be what I ordered, but possibly not what I need. In their picture I mistook the attachment tab for the pivot point in my truck. Possible the folks that restored it used a non-standard pair of rods, instead of the original single rod (as it looks like it was in the drawing).
I'll upload a picture tomorrow (already changed out of my grungy clothes for the day :-).
But now my problem becomes even worse. I've got room to work to get the mid-length pivot point loose. At the pedal pivot bar at the firewall, there is no room whatsoever and seems not obvious how to take the assembly apart as the pedal is seems welded to the pivot bar at 90 degrees making it nearly impossible to maneuver off (I know it can be, since it had to be put together, but its totally not obvious).
