Here is my version of what I came up with for a hood prop. Consists of coupler nuts, 1/4” all thread and 1/8”x 1” flat bar. I like how it works, the rod is bent on purpose to lay in line with the radiator support brace. I haven’t thought of how to firmly store it in the relaxed position yet, (suggestions?).
Obviously it could be in the way when doing some work under the hood. I’m likely to still use the hood resting on the cowl with the rubber triangle at shows. Any comments appreciated.
