| | | Forums66 Topics128,151 Posts1,056,990 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 1,674 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,674 | It looks like you are using the stock water pump from the '61 engine? I believe you need to use the shorter water pump with the smaller pulley?
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engineHere We GoFollow in his DITY Bay- If you think about it, it has been one year ago today!
