Winter is Coming
wave - In following the thought track of "(adding other lights)", below is a pic from UK Bolter "Andrew Sales" from back in 2018 with his 1959 Suburban "School Bus". You can see the added turn signal light below the existing tail light assembly. Basically a front marker/signal light with a yellow lens which are readily available form various vendors. If you really want to continue the theme, add a third same type marker lamp with a clear lens as your back up light directly below the turn signal fixture in a vertical 1 - 2 - 3 pattern. Those lights look kinda OEM or period correct IMHO.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
