If you're going with an open driveline, you HAVE to somehow fix the axle housing to the springs after setting the pinion u-joint axle. Either remove the collars and weld on spring pads or some other method to keep the axle housing from rotating.
Kevin
1951 Chevy 3100 work truck
Photos
