2 members (fonz8261, 1 invisible),
128
0
Mod | | | Forums66 Topics128,119 Posts1,056,317 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,500 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,500 | Yes it is adjustable for length/depth and he provides a chart. That is the one...was designed in the 90s by a gentleman in Taiwan and is a very good design...will last and stay accurate longer. I didn't know he changed his ID, but thanks for letting me know. For the record here is what I like about it: it wipes along a flat surface (the arc sweep ones fail much sooner) the resistance material does not get wiped but is cast to the side where it isn't stressed the wiping surface is actually tiny pieces of metal that have been set into the body of the sender so it will be a very long time before they wear out it is accurate.
